필요한 것
Wedge a spudger between the black front panel and the white outer shell.
Slide the spudger around the edge of the panel to pop it off.
Wedge a nylon spudger between the white outer shell and the battery.
Slowly pull the battery away from the plastic camera cover.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
Do you have the P/N of the battery??
Where to buy a replacement battery?
I believe the battery model is GS24 (3.65V, 600 mAh/21.9Wh).
I also saw this on the battery
GPN: G823-00181-01
Dung Huynh - 답글
