주요 콘텐츠로 건너뛰기
Nest Cam Outdoor S Internal Camera Replacement
필요한 것
  1. Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: 1 단계, 이미지 1/2 Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: 1 단계, 이미지 2/2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Internal Camera Replacement: 2 단계, 이미지 1/1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Internal Camera Replacement: 3 단계, 이미지 1/1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Internal Camera Replacement: 4 단계, 이미지 1/2 Nest Cam Outdoor S Internal Camera Replacement: 4 단계, 이미지 2/2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Internal Camera Replacement, Internal Camera: 5 단계, 이미지 1/1
    • Pry the plastic cover away from the motherboard at the plastic clips using a spudger.
  6. Nest Cam Outdoor S Internal Camera Replacement: 6 단계, 이미지 1/1
    • Remove the four mounting screws from the motherboard.
  7. Nest Cam Outdoor S Internal Camera Replacement: 7 단계, 이미지 1/1
    • Disconnect the yellow camera cable from the motherboard.
    • Remove the camera from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Skylar DeVoe
회원 가입일: 10/28/21
235 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G6
2 회원들
안내서 4개 작성하였습니다
댓글 2개
Can you replace the corn to the actual camera
Cathy Willis - 답글
Can you replace the corn to actual camera
Cathy Willis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 41
전체 시간: 1,650
