필요한 것
Wedge a spudger between the black front panel and the white outer shell.
Slide the spudger around the edge of the panel to pop it off.
Pry the plastic cover away from the motherboard at the plastic clips using a spudger.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Can you replace the corn to the actual camera
Can you replace the corn to actual camera
