주요 콘텐츠로 건너뛰기
Nest Cam Outdoor S Plastic Camera Cover Replacement
필요한 것
  1. Nest Cam Outdoor S Plastic Camera Cover Replacement, Plastic Camera Cover: 1 단계, 이미지 1/2 Nest Cam Outdoor S Plastic Camera Cover Replacement, Plastic Camera Cover: 1 단계, 이미지 2/2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Plastic Camera Cover Replacement: 2 단계, 이미지 1/1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Plastic Camera Cover Replacement: 3 단계, 이미지 1/1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Plastic Camera Cover Replacement: 4 단계, 이미지 1/2 Nest Cam Outdoor S Plastic Camera Cover Replacement: 4 단계, 이미지 2/2
    • Remove the plastic camera cover from the device.
결론
Phelix Gaudette
회원 가입일: 10/28/21
275 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G6
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 26
전체 시간: 517
