주요 콘텐츠로 건너뛰기
Nest Cam Side Snap Locks Replacement
필요한 것
  1. Nest Cam Side Snap Locks Replacement, Side Snap Locks: 1 단계, 이미지 1/1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Side Snap Locks Replacement: 2 단계, 이미지 1/3 Nest Cam Side Snap Locks Replacement: 2 단계, 이미지 2/3 Nest Cam Side Snap Locks Replacement: 2 단계, 이미지 3/3
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Side Snap Locks Replacement: 3 단계, 이미지 1/3 Nest Cam Side Snap Locks Replacement: 3 단계, 이미지 2/3 Nest Cam Side Snap Locks Replacement: 3 단계, 이미지 3/3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Side Snap Locks Replacement: 4 단계, 이미지 1/2 Nest Cam Side Snap Locks Replacement: 4 단계, 이미지 2/2
    • Remove the four 3 mm Phillips #J000 screws from the side snap locks. Remove the old side snap locks and place the new side snap locks.
    • Make sure everything lines up for the screws.
결론
Lisa Langley
회원 가입일: 02/24/16
207 평판
안내서 1개 작성함
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G1
7 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 12
전체 시간: 1,987
