주요 콘텐츠로 건너뛰기
Nest Cam Wi-Fi Cable Replacement
필요한 것
  1. Nest Cam Wi-Fi Cable Replacement, Wi-Fi Cable: 1 단계, 이미지 1/1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Wi-Fi Cable Replacement: 2 단계, 이미지 1/3 Nest Cam Wi-Fi Cable Replacement: 2 단계, 이미지 2/3 Nest Cam Wi-Fi Cable Replacement: 2 단계, 이미지 3/3
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Wi-Fi Cable Replacement: 3 단계, 이미지 1/3 Nest Cam Wi-Fi Cable Replacement: 3 단계, 이미지 2/3 Nest Cam Wi-Fi Cable Replacement: 3 단계, 이미지 3/3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Wi-Fi Cable Replacement: 4 단계, 이미지 1/1
    • Using a soldering iron, melt away the base of the Wi-Fi cable until it can be removed. Use this guild for assistance with soldering.
    • Ensure when you solder the new cable back on that all connector ends are positioned correctly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jade Weiss
회원 가입일: 02/24/16
662 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G1
7 회원들
안내서 10개 작성하였습니다
댓글 2개
I have broken the cable attached to Nest camera. Can you get replacement or repair the lead? Hope i haven't got to buy a new camera
Kerrie Davies - 답글
I have broken lead attached to Nest camera. Can i get a replacement or repair it? Hope i havent got to buy a new camera.
Kerrie Davies - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 4,241
