주요 콘텐츠로 건너뛰기
Nest Dropcam Pro Micro-USB Port Replacement
필요한 것
  1. Nest Dropcam Pro Micro-USB Port Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Micro-USB Port Replacement: 2 단계, 이미지 2개 중 1개 Nest Dropcam Pro Micro-USB Port Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Micro-USB Port Replacement: 3 단계, 이미지 2개 중 1개 Nest Dropcam Pro Micro-USB Port Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Micro-USB Port Replacement: 5 단계, 이미지 2개 중 1개 Nest Dropcam Pro Micro-USB Port Replacement: 5 단계, 이미지 2개 중 2개
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Micro-USB Port Replacement: 6 단계, 이미지 2개 중 1개 Nest Dropcam Pro Micro-USB Port Replacement: 6 단계, 이미지 2개 중 2개
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Micro-USB Port Replacement: 7 단계, 이미지 2개 중 1개 Nest Dropcam Pro Micro-USB Port Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: 8 단계, 이미지 2개 중 1개 Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: 8 단계, 이미지 2개 중 2개
    • Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port.
    • Lift the Micro-USB port away from the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
David Foens
회원 가입일: 09/03/15
896 평판
안내서 6개를 작성함
USF Tampa, Team 15-4, Blackwell Fall 2015 USF Tampa, Team 15-4, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S15G4
3 회원들
안내서 12개를 작성함
4가이드 댓글
I don't have the soldering tools but I used lazerbond to reattach the old port. I hope all the conductors are touching their counter parts. I haven't plugged it back in yet. Wish me luck.
Kreschendalyn Backus - 답글
Did it work for you?
Michael Candy -
Where can you order the micro-usb charge port for this cam?
Danny Acevedo - 답글
Not sure where you get them but according to one site it uses a Micro USB 2.0 Type B Receptacle.
https://bit.ly/2Kg01z6
Debbie - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 40
전체 시간: 6,076
