소개
This guide is needed to replace the mounting clips if they do not securely hold the camera in its mount. Make sure the device is unplugged before opening.
필요한 것
Press in the mounting clips on each side of the case to remove the camera from the mount.
Using a Philips #0 screwdriver, remove the four 4 mm screws that are attaching the mounting clips to the case.
거의 끝나갑니다!
결론
