주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nest Hello Camera Replacement
필요한 것
    1. Nest Hello Camera Replacement, Casing and Faceplate: 1 단계, 이미지 1개 중 1개
      • Insert the pick between the black faceplate and white casing of the Nest Hello.
      • Pry the faceplate away from the device with the opening pick.
      • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
      • Completely remove the faceplate from the device, do not be afraid to pull hard.
      댓글 쓰기
    2. Nest Hello Camera Replacement: 2 단계, 이미지 2개 중 1개 Nest Hello Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
      댓글 쓰기
    3. Nest Hello Camera Replacement: 3 단계, 이미지 3개 중 1개 Nest Hello Camera Replacement: 3 단계, 이미지 3개 중 2개 Nest Hello Camera Replacement: 3 단계, 이미지 3개 중 3개
      • Insert opening pick between the white casing and the black internal circuitry and pry it out.
      • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
      댓글 쓰기
    1. Nest Hello Camera Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
      • Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
      댓글 쓰기
    2. Nest Hello Camera Replacement: 5 단계, 이미지 2개 중 1개 Nest Hello Camera Replacement: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Grip the connector with the tweezers as shown and pull it away from the casing.
      댓글 쓰기
    3. Nest Hello Camera Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the six smaller screws shown with the Phillips #000 screwdriver.
      • Remove the three larger screws shown with the Phillips #000 screwdriver.
      댓글 쓰기
    4. Nest Hello Camera Replacement: 7 단계, 이미지 2개 중 1개 Nest Hello Camera Replacement: 7 단계, 이미지 2개 중 2개
      • Holding the device as shown push the circuit board away from you and up to free it from the clips.
      댓글 쓰기
    5. Nest Hello Camera Replacement: 8 단계, 이미지 2개 중 1개 Nest Hello Camera Replacement: 8 단계, 이미지 2개 중 2개
      • Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
      댓글 쓰기
    6. Nest Hello Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
      • Work your way around the device, prying the circuit board away from the housing.
      • Make sure to feed the wires when taking off the circuit board.
      댓글 쓰기
    1. Nest Hello Camera Replacement, Camera: 10 단계, 이미지 3개 중 1개 Nest Hello Camera Replacement, Camera: 10 단계, 이미지 3개 중 2개 Nest Hello Camera Replacement, Camera: 10 단계, 이미지 3개 중 3개
      • Remove the plug connecting the camera to the device.
      댓글 쓰기
    2. Nest Hello Camera Replacement: 11 단계, 이미지 3개 중 1개 Nest Hello Camera Replacement: 11 단계, 이미지 3개 중 2개 Nest Hello Camera Replacement: 11 단계, 이미지 3개 중 3개
      • Lift the top layer of circuits to reveal the unplugged camera.
      • Lift up the camera and remove it from the device.
      • If you flip the camera upside down a black rubber rectangle will fall out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 39
전체 시간: 2,868
