주요 콘텐츠로 건너뛰기
Nest Hello Casing and Faceplate Replacement
필요한 것
  1. Nest Hello Casing and Faceplate Replacement, Casing and Faceplate: 1 단계, 이미지 1개 중 1개
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello Casing and Faceplate Replacement: 2 단계, 이미지 2개 중 1개 Nest Hello Casing and Faceplate Replacement: 2 단계, 이미지 2개 중 2개
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello Casing and Faceplate Replacement: 3 단계, 이미지 3개 중 1개 Nest Hello Casing and Faceplate Replacement: 3 단계, 이미지 3개 중 2개 Nest Hello Casing and Faceplate Replacement: 3 단계, 이미지 3개 중 3개
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
결론
작성자
3다른 기여자 명과 함께
Daniel Moore
회원 가입일: 01/14/20
902 평판
안내서 6개를 작성함
2가이드 댓글
Are Replacement parts available anywhere? Can’t seem to find anything… thanks!
Andres Chavez - 답글
Aside from fine grit sanding and spray painting or using a silicone cover, has anyone found a creative way to fix the delaminated an existing Gen 1 Google Nest wired / Nest Hello doorbell faceplate (remove the rest of the flaking off laminate)?
RickSoFlo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 78
전체 시간: 3,201
