주요 콘텐츠로 건너뛰기
Nest Hello Motherboard Replacement
필요한 것
  1. Nest Hello Motherboard Replacement, Casing and Faceplate: 1 단계, 이미지 1개 중 1개
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Nest Hello Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Nest Hello Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Nest Hello Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
  4. Nest Hello Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
  5. Nest Hello Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Nest Hello Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Grip the connector with the tweezers as shown and pull it away from the casing.
  6. Nest Hello Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the six smaller screws shown with the Phillips #000 screwdriver.
    • Remove the three larger screws shown with the Phillips #000 screwdriver.
  7. Nest Hello Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Nest Hello Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Holding the device as shown push the circuit board away from you and up to free it from the clips.
  8. Nest Hello Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Nest Hello Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
  9. Nest Hello Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
    • Work your way around the device, prying the circuit board away from the housing.
    • Make sure to feed the wires when taking off the circuit board.
결론
작성자
4다른 기여자 명과 함께
Daniel Moore
회원 가입일: 01/14/20
902 평판
안내서 6개를 작성함
2가이드 댓글
@viteapen13 Hi Daniel, question for you. On step 9, is the enclosing shell for the main board (top portion of the photo) metallic or plastic? Also, the blue material off the shell foam? Last, the blue regular stuff from the bottom board, is that some kind of thermal paste? Thanks.
Monty the Real - 답글
Any idea which portion is the wifi connection? The doorbell wifi goes in and out and the camera works. I have a entire new doorbell I bought for cheap for parts. Which part should I change?
Rlau - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 31
전체 시간: 1,451
