주요 콘텐츠로 건너뛰기
Nest Hello O-Ring Replacement
필요한 것
  1. Nest Hello O-Ring Replacement, Casing and Faceplate: 1 단계, 이미지 1개 중 1개
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello O-Ring Replacement: 2 단계, 이미지 2개 중 1개 Nest Hello O-Ring Replacement: 2 단계, 이미지 2개 중 2개
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello O-Ring Replacement: 3 단계, 이미지 3개 중 1개 Nest Hello O-Ring Replacement: 3 단계, 이미지 3개 중 2개 Nest Hello O-Ring Replacement: 3 단계, 이미지 3개 중 3개
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
  4. Nest Hello O-Ring Replacement, O-Ring: 4 단계, 이미지 1개 중 1개
    • Remove the O-Ring (colored blue) from the device. It is placed around the edge of the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jason Valencia
회원 가입일: 01/14/20
389 평판
안내서 1개를 작성함
2가이드 댓글
Is there a link available for spare replacement parts? I can’t seem to find anything other than replacement internal batteries . Thanks!
Andres Chavez - 답글
Also looking for this replacement part. Googling did not produce results.
KB_KB - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 31
지난 30일: 148
전체 시간: 4,550
