주요 콘텐츠로 건너뛰기
Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement
필요한 것
  1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Removal from Wall: 1 단계, 이미지 2개 중 1개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Removal from Wall: 1 단계, 이미지 2개 중 2개
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  2. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Open Display: 2 단계, 이미지 1개 중 1개
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
  3. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove the back of the display: 3 단계, 이미지 2개 중 1개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove the back of the display: 3 단계, 이미지 2개 중 2개
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
  4. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: 4 단계, 이미지 3개 중 1개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: 4 단계, 이미지 3개 중 2개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: 4 단계, 이미지 3개 중 3개
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
  5. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Lift battery from the base: 5 단계, 이미지 2개 중 1개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Lift battery from the base: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
  6. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the battery from the motherboard: 6 단계, 이미지 2개 중 1개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the battery from the motherboard: 6 단계, 이미지 2개 중 2개
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  7. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: 7 단계, 이미지 3개 중 1개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: 7 단계, 이미지 3개 중 2개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: 7 단계, 이미지 3개 중 3개
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
  8. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Locate auto-away sensor: 8 단계, 이미지 1개 중 1개
    • Locate the auto-away sensor.
  9. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove screws: 9 단계, 이미지 2개 중 1개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove screws: 9 단계, 이미지 2개 중 2개
    • Remove the four 3mm screws with a #0 Phillips screwdriver.
    • Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
  10. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: 10 단계, 이미지 3개 중 1개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: 10 단계, 이미지 3개 중 2개 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Lift the auto-away sensor from motherboard using tweezers.
    • Peel the copper foil gently from the EMI shield.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Justin Curry
회원 가입일: 09/23/14
264 평판
안내서 2개를 작성함
USF Tampa, Team 11-5, Blackwell Fall 2014 USF Tampa, Team 11-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G5
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 2,281
