주요 콘텐츠로 건너뛰기
Nest Protect Backplate Replacement
    • Remove the Protect from it’s backplate by twisting counterclockwise on the device until it releases.
    • Unscrew the backplate.
    • Battery operated: Fully remove the backplate screws.
    • Hardwired: Slightly remove the backplate screws and twist the backplate.
    • Pull the backplate off the wall.
    • Place the backplate on the wall.
    • Battery Operated: Screw in the backplate.
    • Hardwired: Twist the backplate so it locks into place and snug the screws
    • 1ST Generation: Twist clockwise until it clicks into place
    • 2ND Generation: Twist clockwise until it grips and adjust to fit the wall or ceiling of wall mounted.
결론
작성자
1다른 기여자 명과 함께
Logan
회원 가입일: 04/24/19
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 19
전체 시간: 2,641
