주요 콘텐츠로 건너뛰기
Nest Thermostat E Base Plate Replacement
필요한 것
  1. Nest Thermostat E Base Plate Replacement, Base Plate: 1 단계, 이미지 1개 중 1개
    • Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
    • Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
    • Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
    • Remember the placement of each wire for reassembly.
  2. Nest Thermostat E Base Plate Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
    • Remove the base plate and base display.
  3. Nest Thermostat E Base Plate Replacement: 3 단계, 이미지 1개 중 1개
    • Pry the base display off of the baseplate using an iFixit opening tool.
결론
작성자
4다른 기여자 명과 함께
Andrew Ahlborn
회원 가입일: 02/27/23
368 평판
안내서 3개를 작성함
1가이드 댓글
Any recommendations on where to get 2nd and 3rd gen base plates. Both burned by lightning...
elippert - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 28
전체 시간: 1,084
