주요 콘텐츠로 건너뛰기
Nest Thermostat E Dial Replacement
필요한 것
  1. Nest Thermostat E Dial Replacement, Base Plate: 1 단계, 이미지 1개 중 1개
    • Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
    • Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
    • Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
    • Remember the placement of each wire for reassembly.
  2. Nest Thermostat E Dial Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
    • Remove the base plate and base display.
  3. Nest Thermostat E Dial Replacement: 3 단계, 이미지 1개 중 1개
    • Pry the base display off of the baseplate using an iFixit opening tool.
  4. Nest Thermostat E Dial Replacement, Dial: 4 단계, 이미지 1개 중 1개
    • Remove the four 6 mm screws using a Phillips #0 screwdriver.
    • The two smaller screws go around the pin connector and the two larger screws go by the outside bezel.
    • Grab the pin connector and pull up to remove the thermostat backplate from the thermostat.
  5. Nest Thermostat E Dial Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the four screws.
  6. Nest Thermostat E Dial Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Grasp the orange tab with tweezers and gently pull the ribbon cable directly away from the motherboard.
  7. Nest Thermostat E Dial Replacement: 7 단계, 이미지 1개 중 1개
    • Flip the display over and the battery casing will fall from the base.
  8. Nest Thermostat E Dial Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the six screws.
  9. Nest Thermostat E Dial Replacement: 9 단계, 이미지 2개 중 1개 Nest Thermostat E Dial Replacement: 9 단계, 이미지 2개 중 2개
    • Push out the display from the dial.
    • You might have to twist slightly.
    • Do not apply too much force which might cause the Nest Thermostat E screen to break.
    • You might hear a pop which signifies that the display came out of the display holder.
결론
작성자
4다른 기여자 명과 함께
Matthew Spector
회원 가입일: 03/01/23
182 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 18
전체 시간: 487
