주요 콘텐츠로 건너뛰기
소개
This guide will provide instructions on removing the damaged or broken case. To best use this guide the Phillips 00 screwdriver is recommended. The Phillips 000 or 0 may work as well, please note that the smaller the screwdriver the higher chances of stripping the screw. It is also recommended to have a plastic opening tool (blue) to gently pull the device apart and a bowl or container to keep the small and easily lost screws in.
부품
지정된 부품이 없습니다.
  1. Netgear Arlo 2 Camera HD Security System Case Replacement, Case: 1 단계, 이미지 1/3 Netgear Arlo 2 Camera HD Security System Case Replacement, Case: 1 단계, 이미지 2/3 Netgear Arlo 2 Camera HD Security System Case Replacement, Case: 1 단계, 이미지 3/3
    • Unscrew the two 3.0 mm Phillips #00 screws on the bottom of the camera.
    • Open the battery compartment on the bottom by pushing the switch marked in orange to the side and pushing the bottom of the camera back, sliding it open.
  2. Netgear Arlo 2 Camera HD Security System Case Replacement: 2 단계, 이미지 1/2 Netgear Arlo 2 Camera HD Security System Case Replacement: 2 단계, 이미지 2/2
    • Remove the bottom piece of the case over the battery compartment by placing a plastic opening tool underneath the edge of the case and prying it up.
    • Unscrew the four 3.0 mm Phillips #00 screws on the outside of the battery pocket.
  3. Netgear Arlo 2 Camera HD Security System Case Replacement: 3 단계, 이미지 1/2 Netgear Arlo 2 Camera HD Security System Case Replacement: 3 단계, 이미지 2/2
    • When facing the camera lens, the left panel of the case will be removed first (more steps are needed for the right panel).
    • Place the plastic opening tool between the two pieces of the case and pry them apart from the bottom.
    • Gently pull the side of the case off as it comes loose.
  4. Netgear Arlo 2 Camera HD Security System Case Replacement: 4 단계, 이미지 1/2 Netgear Arlo 2 Camera HD Security System Case Replacement: 4 단계, 이미지 2/2
    • Unscrew the smaller 3.0 mm Phillips #00 screw in the center on the back of the device.
    • Flip the camera over and unscrew the center 3.0 mm Phillips #00 screw above the SYNC button.
  5. Netgear Arlo 2 Camera HD Security System Case Replacement: 5 단계, 이미지 1/2 Netgear Arlo 2 Camera HD Security System Case Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, gently pry the right panel from the device.
    • Replace either side of the plastic case as needed.
결론
Katherine McCombs
회원 가입일: 2018년 10월 25일
469 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G4, Peak Fall 2018 UMass Dartmouth, Team S2-G4, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 1,000
