이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unscrew the two 3.0 mm Phillips #00 screws on the bottom of the camera.
Open the battery compartment on the bottom by pushing the switch marked in orange to the side and pushing the bottom of the camera back, sliding it open.
Remove the bottom piece of the case over the battery compartment by placing a plastic opening tool underneath the edge of the case and prying it up.
Unscrew the four 3.0 mm Phillips #00 screws on the outside of the battery pocket.
When facing the camera lens, the left panel of the case will be removed first (more steps are needed for the right panel).
Place the plastic opening tool between the two pieces of the case and pry them apart from the bottom.
Gently pull the side of the case off as it comes loose.
Unscrew the smaller 3.0 mm Phillips #00 screw in the center on the back of the device.
Flip the camera over and unscrew the center 3.0 mm Phillips #00 screw above the SYNC button.
Using the plastic opening tool, gently pry the right panel from the device.
Replace either side of the plastic case as needed.
Unscrew the two 3.0 mm Phillips #00 screws on either side of the SYNC button.
Remove the white plastic covering.
Remove the white SYNC button.
