주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Netgear Arlo Infrared LED Board Replacement
필요한 것
  1. Netgear Arlo Infrared LED Board Replacement, Plastic Housing: 1 단계, 이미지 1개 중 1개
    • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
  2. Netgear Arlo Infrared LED Board Replacement: 2 단계, 이미지 2개 중 1개 Netgear Arlo Infrared LED Board Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
  3. Netgear Arlo Infrared LED Board Replacement: 3 단계, 이미지 1개 중 1개
    • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
  4. Netgear Arlo Infrared LED Board Replacement: 4 단계, 이미지 3개 중 1개 Netgear Arlo Infrared LED Board Replacement: 4 단계, 이미지 3개 중 2개 Netgear Arlo Infrared LED Board Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
    • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
    • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
  5. Netgear Arlo Infrared LED Board Replacement: 5 단계, 이미지 3개 중 1개 Netgear Arlo Infrared LED Board Replacement: 5 단계, 이미지 3개 중 2개 Netgear Arlo Infrared LED Board Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
    • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
    • Once the screws are removed use an opening tool to pry back the second plastic mount.
  6. Netgear Arlo Infrared LED Board Replacement, Lens Assembly: 6 단계, 이미지 1개 중 1개
    • Remove 4 (6mm) large screws with a J00 screwdriver.
    • There are 2 on each side. This will allow you to remove the clear housing from the white housing.
  7. Netgear Arlo Infrared LED Board Replacement: 7 단계, 이미지 2개 중 1개 Netgear Arlo Infrared LED Board Replacement: 7 단계, 이미지 2개 중 2개
    • Once screws are removed, pull apart the clear housing.
    • Remove rod from camera cover.
  8. Netgear Arlo Infrared LED Board Replacement: 8 단계, 이미지 3개 중 1개 Netgear Arlo Infrared LED Board Replacement: 8 단계, 이미지 3개 중 2개 Netgear Arlo Infrared LED Board Replacement: 8 단계, 이미지 3개 중 3개
    • Remove Large ribbon cable first to disconnect front of camera from main body.
    • Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
    • Remove smaller ribbon cable from underneath yellow tape.
  9. Netgear Arlo Infrared LED Board Replacement: 9 단계, 이미지 1개 중 1개
    • Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
  10. Netgear Arlo Infrared LED Board Replacement, Infrared LED Board: 10 단계, 이미지 1개 중 1개
    • Remove 3 (.150") screws from the sync board using the JIS00 screwdriver.
  11. Netgear Arlo Infrared LED Board Replacement: 11 단계, 이미지 2개 중 1개 Netgear Arlo Infrared LED Board Replacement: 11 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to slowly pry the board away from the front housing.
결론
작성자
2다른 기여자 명과 함께
Daniel Bailey
회원 가입일: 03/21/18
85 평판
안내서 1개를 작성함
IUPUI, Team S2-G1, Freund Spring 2018 IUPUI, Team S2-G1, Freund Spring 2018 회원
IUPUI-FREUND-S18S2G1
2 회원들
안내서 4개를 작성함
3가이드 댓글
Great tutorial, thanks a lot.
I have a problem with infrared, Netgear isn’t able to help me without seeing the camera.
I would like to ask you….
In the night the red leds light on but you see all black, there is no light entering in the lens system. I think there is a problem in the diaphragm… what do you think?
The first months it works correctly (except once when I see all pink, I fix it restarted the camera).
Thank you!
Matteo
matteor84@hotmail.it
Matteo Runfola - 답글 공유
Where can you buy the board and other parts?
Jay Hartman - 답글 공유
I’d like to know too. This repair guide is no help if you can’t buy the parts needed to complete the repair.
D. Liseckas - 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 21
전체 시간: 2,665
