주요 콘텐츠로 건너뛰기
Netgear Arlo Lens Assembly Replacement
필요한 것
  1. Netgear Arlo Lens Assembly Replacement, Plastic Housing: 1 단계, 이미지 1개 중 1개
    • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
  2. Netgear Arlo Lens Assembly Replacement: 2 단계, 이미지 2개 중 1개 Netgear Arlo Lens Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
  3. Netgear Arlo Lens Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
  4. Netgear Arlo Lens Assembly Replacement: 4 단계, 이미지 3개 중 1개 Netgear Arlo Lens Assembly Replacement: 4 단계, 이미지 3개 중 2개 Netgear Arlo Lens Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
    • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
    • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
  5. Netgear Arlo Lens Assembly Replacement: 5 단계, 이미지 3개 중 1개 Netgear Arlo Lens Assembly Replacement: 5 단계, 이미지 3개 중 2개 Netgear Arlo Lens Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
    • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
    • Once the screws are removed use an opening tool to pry back the second plastic mount.
  6. Netgear Arlo Lens Assembly Replacement, Lens Assembly: 6 단계, 이미지 1개 중 1개
    • Remove 4 (6mm) large screws with a J00 screwdriver.
    • There are 2 on each side. This will allow you to remove the clear housing from the white housing.
  7. Netgear Arlo Lens Assembly Replacement: 7 단계, 이미지 2개 중 1개 Netgear Arlo Lens Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Once screws are removed, pull apart the clear housing.
    • Remove rod from camera cover.
  8. Netgear Arlo Lens Assembly Replacement: 8 단계, 이미지 3개 중 1개 Netgear Arlo Lens Assembly Replacement: 8 단계, 이미지 3개 중 2개 Netgear Arlo Lens Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Remove Large ribbon cable first to disconnect front of camera from main body.
    • Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
    • Remove smaller ribbon cable from underneath yellow tape.
  9. Netgear Arlo Lens Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
결론
작성자
3다른 기여자 명과 함께
Connor Krampen
회원 가입일: 01/08/18
399 평판
안내서 3개를 작성함
IUPUI, Team S1-G1, Freund Spring 2018 IUPUI, Team S1-G1, Freund Spring 2018 회원
IUPUI-FREUND-S18S1G1
2 회원들
안내서 6개를 작성함
8가이드 댓글
toller Tipp! Weiß jemand, wo man die Linse kaufen kann.?
familie - 답글
Wo bekomme ich ein neues Gehäuse?
piet - 답글
hi I took out the battery befor it was finished downloading new firmware, now there is no connection, no blue light. Can you help or is the camer garbage?
Rune Koppang - 답글
I struggled a bit with the ribbon cable connections, they need to be lifted up from the side the cable enters. They are sort of hinged like a door but lying on its side. Once it is stood up vertically, the cable will pull out. For the longer one I found it was important to lift as much of it up at once otherwise it will break if you lift one end and not the other. Once the cable is reinserted, they can just be pushed back down, same as before, supporting the full length when you do. If one comes off it is possible to push it back onto the hinge but it is very very tricky and took a while.
Richard Bailey - 답글
Where did you get the replacement lens?
G. N. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 31
전체 시간: 5,347
