주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Netgear Arlo Plastic Housing Replacement
필요한 것
  1. Netgear Arlo Plastic Housing Replacement, Battery: 1 단계, 이미지 3개 중 1개 Netgear Arlo Plastic Housing Replacement, Battery: 1 단계, 이미지 3개 중 2개 Netgear Arlo Plastic Housing Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Locate unlock switch on underside of camera and unlock it by sliding it.
    • Once unlocked, slide the cover out and up to open the battery housing.
    댓글 쓰기
  2. Netgear Arlo Plastic Housing Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all 4 of the 3.0 Volt batteries from the battery housing.
    댓글 쓰기
  3. Netgear Arlo Plastic Housing Replacement: 3 단계, 이미지 1개 중 1개
    • Inspect prongs at the bottom of the battery housing to ensure that they are not bent or broken before replacing the batteries.
    댓글 쓰기
  4. Netgear Arlo Plastic Housing Replacement, Plastic Housing: 4 단계, 이미지 1개 중 1개
    • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
    댓글 쓰기
  5. Netgear Arlo Plastic Housing Replacement: 5 단계, 이미지 2개 중 1개 Netgear Arlo Plastic Housing Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
    댓글 쓰기
  6. Netgear Arlo Plastic Housing Replacement: 6 단계, 이미지 1개 중 1개
    • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
    댓글 쓰기
  7. Netgear Arlo Plastic Housing Replacement: 7 단계, 이미지 3개 중 1개 Netgear Arlo Plastic Housing Replacement: 7 단계, 이미지 3개 중 2개 Netgear Arlo Plastic Housing Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
    • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
    • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
    댓글 쓰기
  8. Netgear Arlo Plastic Housing Replacement: 8 단계, 이미지 3개 중 1개 Netgear Arlo Plastic Housing Replacement: 8 단계, 이미지 3개 중 2개 Netgear Arlo Plastic Housing Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
    • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
    • Once the screws are removed use an opening tool to pry back the second plastic mount.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Connor Krampen
회원 가입일: 01/08/18
399 평판
안내서 3개를 작성함
IUPUI, Team S1-G1, Freund Spring 2018 IUPUI, Team S1-G1, Freund Spring 2018 회원
IUPUI-FREUND-S18S1G1
2 회원들
안내서 6개를 작성함
2가이드 댓글
Where can I buy replacement parts like a battery cover for Arlo
L R Hardy - 답글 공유
Note that under the rubber cover shown in step 6 there is a USB-B port.
You can run the Arlo on a USB adapter as well.
You only need to make a hole in the battery lid or 3D print a new cover.
Bas Vijfwinkel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 60
전체 시간: 2,905
