주요 콘텐츠로 건너뛰기
Netgear WGR614v9 Motherboard Replacement
필요한 것
  1. Netgear WGR614v9 Motherboard Replacement, Lower Case: 1 단계, 이미지 1/1
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Motherboard Replacement: 2 단계, 이미지 1/2 Netgear WGR614v9 Motherboard Replacement: 2 단계, 이미지 2/2
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Motherboard Replacement: 3 단계, 이미지 1/2 Netgear WGR614v9 Motherboard Replacement: 3 단계, 이미지 2/2
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Motherboard Replacement: 4 단계, 이미지 1/1
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Motherboard Replacement: 6 단계, 이미지 1/2 Netgear WGR614v9 Motherboard Replacement: 6 단계, 이미지 2/2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
결론
Ryan Murphy
회원 가입일: 10/03/11
488 평판
안내서 4개 작성하였습니다
Cal Poly, Team 21-24, Maness Fall 2011 Cal Poly, Team 21-24, Maness Fall 2011 회원
CPSU-MANESS-F11S21G24
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 2,220
