주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
NeuTab N9 Camera Replacement
필요한 것
  1. NeuTab N9 Camera Replacement, Camera: 1 단계, 이미지 1개 중 1개
    • Turn off your device before beginning these steps.
    • Insert the plastic opening tool into the seam between the screen and the back of the tablet. Move the opening tool along the seam until the back of the tablet releases.
  2. NeuTab N9 Camera Replacement: 2 단계, 이미지 2개 중 1개 NeuTab N9 Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Locate your camera in the corner of your tablet, connected to the circuit board.
    • Insert your plastic opening tool into the clip that secures the camera ribbon to the circuit board. Gently pry up until the clip releases its hold on the ribbon.
  3. NeuTab N9 Camera Replacement: 3 단계, 이미지 1개 중 1개
    • The rear-facing camera module of the tablet is secured to the device with a strong adhesive. Insert your plastic opening tool underneath the rear-facing camera module and gently pry it up until it is released from the glue. You may now remove the entire camera assembly.
결론
작성자
2다른 기여자 명과 함께
Allan Lieu
회원 가입일: 09/20/17
306 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 44
전체 시간: 266
