주요 콘텐츠로 건너뛰기
Newport HT70 Plus Ventilator Air Intake Filter Replacement
필요한 것
  1. Newport HT70 Plus Ventilator Air Intake Filter Replacement, Air intake Filter: 1 단계, 이미지 1/1
    • Make sure that the Ventilator is turned OFF. The power switch is located in the back side of the ventilator.
    • Remove the Power Cord.
  2. Newport HT70 Plus Ventilator Air Intake Filter Replacement: 2 단계, 이미지 1/3 Newport HT70 Plus Ventilator Air Intake Filter Replacement: 2 단계, 이미지 2/3 Newport HT70 Plus Ventilator Air Intake Filter Replacement: 2 단계, 이미지 3/3
    • Locate the right panel of the Ventilator.
    • Remove the Air O2 mixer by rotating it counterclockwise, and then pull the mixer out.
  3. Newport HT70 Plus Ventilator Air Intake Filter Replacement: 3 단계, 이미지 1/1
    • Remove the two thumbscrews by twisting then counterclockwise.
    • Remove the filter cover. Use a prying tool if needed.
  4. Newport HT70 Plus Ventilator Air Intake Filter Replacement: 4 단계, 이미지 1/2 Newport HT70 Plus Ventilator Air Intake Filter Replacement: 4 단계, 이미지 2/2
    • Replace the old filter with the new one.
    • Once replaced, place back the Filter cover.
    • Screw the thumbscrews back into place, fastening them clockwise.
  5. Newport HT70 Plus Ventilator Air Intake Filter Replacement: 5 단계, 이미지 1/1
    • Run a Circuit Check before you install the air O2 mixer back into place.
    • Place back the air O2 mixer by adjusting the flanges into the proper position. And then rotate the air mixer clockwise to lock into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jorge Castillo
회원 가입일: 04/10/20
201 평판
안내서 1개 작성함
Cal Poly, Team S7-G5, Paton Spring 2020 Cal Poly, Team S7-G5, Paton Spring 2020 회원
CPSU-PATON-S20S7G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 331
