주요 콘텐츠로 건너뛰기
NexiGo NS32 Battery Replacement
필요한 것
  1. NexiGo NS32 Battery Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Orient the controller so that it is face down.
  2. NexiGo NS32 Battery Replacement: 2 단계, 이미지 2개 중 1개 NexiGo NS32 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the eight 9 mm Phillips screws that secure the rear case.
  3. NexiGo NS32 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
  4. NexiGo NS32 Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 NexiGo NS32 Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Grip the white battery connector and pull it directly out of its motherboard socket.
    • This may require some force, as the connectors are secured with a bit of adhesive. If you're having trouble with disconnection, apply some high-concentration isopropyl alcohol to the adhesive to loosen it.
    • Do not pull on the wires.
  5. NexiGo NS32 Battery Replacement: 5 단계, 이미지 3개 중 1개 NexiGo NS32 Battery Replacement: 5 단계, 이미지 3개 중 2개 NexiGo NS32 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the battery up and out.
    • Take care not to bend or puncture the battery as you remove it.
결론
작성자
4다른 기여자 명과 함께
Matthew Nguyen
회원 가입일: 01/29/24
235 평판
안내서 1개를 작성함
1가이드 댓글
Do you know what model battery I would need to buy to replace the original?
Jack Dunne - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 247
