주요 콘텐츠로 건너뛰기
NexiGo NS32 Trigger Assembly Replacement
필요한 것
  1. NexiGo NS32 Trigger Assembly Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Orient the controller so that it is face down.
  2. NexiGo NS32 Trigger Assembly Replacement: 2 단계, 이미지 2개 중 1개 NexiGo NS32 Trigger Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the eight 9 mm Phillips screws that secure the rear case.
  3. NexiGo NS32 Trigger Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
  4. NexiGo NS32 Trigger Assembly Replacement, Battery: 4 단계, 이미지 2개 중 1개 NexiGo NS32 Trigger Assembly Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Grip the white battery connector and pull it directly out of its motherboard socket.
    • This may require some force, as the connectors are secured with a bit of adhesive. If you're having trouble with disconnection, apply some high-concentration isopropyl alcohol to the adhesive to loosen it.
    • Do not pull on the wires.
  5. NexiGo NS32 Trigger Assembly Replacement: 5 단계, 이미지 3개 중 1개 NexiGo NS32 Trigger Assembly Replacement: 5 단계, 이미지 3개 중 2개 NexiGo NS32 Trigger Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the battery up and out.
    • Take care not to bend or puncture the battery as you remove it.
  6. NexiGo NS32 Trigger Assembly Replacement, Joystick PCB: 6 단계, 이미지 2개 중 1개 NexiGo NS32 Trigger Assembly Replacement, Joystick PCB: 6 단계, 이미지 2개 중 2개
    • Remove the three 9 mm Phillips screws that secure the joystick PCB.
  7. NexiGo NS32 Trigger Assembly Replacement: 7 단계, 이미지 2개 중 1개 NexiGo NS32 Trigger Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Flip up the black ZIF connector locking flap on the left side of the joystick PCB.
    • Pull the ribbon cable directly out of its socket.
  8. NexiGo NS32 Trigger Assembly Replacement: 8 단계, 이미지 3개 중 1개 NexiGo NS32 Trigger Assembly Replacement: 8 단계, 이미지 3개 중 2개 NexiGo NS32 Trigger Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Lift out the joystick PCB.
  9. NexiGo NS32 Trigger Assembly Replacement, Trigger Assembly: 9 단계, 이미지 1개 중 1개
    • Flip up the black ZIF locking flap that secures the trigger assembly ribbon cable.
    • Disconnect the ribbon cable.
  10. NexiGo NS32 Trigger Assembly Replacement: 10 단계, 이미지 2개 중 1개 NexiGo NS32 Trigger Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Gently lift out the trigger assembly.
결론
작성자
2다른 기여자 명과 함께
Gage_Atx
회원 가입일: 01/29/24
85 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 190
