주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nextbook 8 Battery Replacement
필요한 것
  1. Nextbook 8 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nextbook 8 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Battery Replacement: 2 단계, 이미지 2개 중 1개 Nextbook 8 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Battery Replacement: 3 단계, 이미지 2개 중 1개 Nextbook 8 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Battery Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Battery Replacement: 5 단계, 이미지 2개 중 1개 Nextbook 8 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
결론
다른 24명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Dylan Wiese
회원 가입일: 03/11/15
1,889 평판
안내서 5개를 작성함
Colorado Springs, Team 5-1, Panko Spring 2015 Colorado Springs, Team 5-1, Panko Spring 2015 회원
UCCS-PANKO-S15S5G1
3 회원들
안내서 10개를 작성함
5가이드 댓글
Very helpful and well made.
Quentin Freed - 답글 공유
Where can I buy the battery???
scruff67 - 답글 공유
Check Ebay. That's where I'm headed right now.
Tina Carey - 공유
im having connection issues i cant find any wifi period
crusher309 - 답글 공유
Hello,
Yes well, but what is th voltage battery?
Thanks
Tyeroued - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 69
전체 시간: 43,028
