소개
You will need a thin durable tool to get the back cover off first. A guitar pick works well if you don't have a plastic opening tool. The parts are very delicate, so use caution when removing the back cover and inner parts.
필요한 것
Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
Slide the tool along the edge to work the back cover off.
다른 22명이 해당 안내서를 완성하였습니다.
댓글 4개
Very helpful and well made.
Check Ebay. That's where I'm headed right now.
im having connection issues i cant find any wifi period
crusher309 - 답글
