주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nextbook 8 Screen Replacement
필요한 것
  1. Nextbook 8 Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nextbook 8 Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Screen Replacement: 2 단계, 이미지 2개 중 1개 Nextbook 8 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Screen Replacement: 3 단계, 이미지 2개 중 1개 Nextbook 8 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Screen Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Screen Replacement: 5 단계, 이미지 2개 중 1개 Nextbook 8 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
  6. Nextbook 8 Screen Replacement, Screen: 6 단계, 이미지 1개 중 1개
    • Remove the silver and gold sticker at the bottom of the device.
    • Hold the brown circuit board down with your finger while you remove the sticker
  7. Nextbook 8 Screen Replacement: 7 단계, 이미지 2개 중 1개 Nextbook 8 Screen Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a spudger to lift up the black tabs on the three ZIF connectors.
    • Use ESD safe tweezers to pull the ribbon cables out of the three connectors.
  8. Nextbook 8 Screen Replacement: 8 단계, 이미지 2개 중 1개 Nextbook 8 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the 5 black screws on the motherboard.
    • Carefully lift the motherboard off of the device and remove.
  9. Nextbook 8 Screen Replacement: 9 단계, 이미지 2개 중 1개 Nextbook 8 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the two screws that hold the brackets in place.
    • Remove the two silver brackets that hold the screen in place.
  10. Nextbook 8 Screen Replacement: 10 단계, 이미지 2개 중 1개 Nextbook 8 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the one silver screw on the small green circuit board at the bottom of the device.
    • Set aside the small circuit board for now.
  11. Nextbook 8 Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the two silver screws from the bottom of the device.
  12. Nextbook 8 Screen Replacement: 12 단계, 이미지 3개 중 1개 Nextbook 8 Screen Replacement: 12 단계, 이미지 3개 중 2개 Nextbook 8 Screen Replacement: 12 단계, 이미지 3개 중 3개
    • With the device face down, use a spudger to lift the screen off of the glass from the right side.
결론
다른 21명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Dylan Wiese
회원 가입일: 03/11/15
1,889 평판
안내서 5개를 작성함
Colorado Springs, Team 5-1, Panko Spring 2015 Colorado Springs, Team 5-1, Panko Spring 2015 회원
UCCS-PANKO-S15S5G1
3 회원들
안내서 10개를 작성함
1가이드 댓글
where do I find the actual screen though
WiKiT Woo WoNKa - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 23
전체 시간: 24,185
