주요 콘텐츠로 건너뛰기
Nextbook 8 Speaker Replacement
필요한 것
  1. Nextbook 8 Speaker Replacement, Battery: 1 단계, 이미지 1/2 Nextbook 8 Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Speaker Replacement: 2 단계, 이미지 1/2 Nextbook 8 Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Speaker Replacement: 3 단계, 이미지 1/2 Nextbook 8 Speaker Replacement: 3 단계, 이미지 2/2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Speaker Replacement: 4 단계, 이미지 1/1
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Speaker Replacement: 5 단계, 이미지 1/2 Nextbook 8 Speaker Replacement: 5 단계, 이미지 2/2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
  6. Nextbook 8 Speaker Replacement, Speaker: 6 단계, 이미지 1/1
    • Use a small Phillips screwdriver to remove the 0.116 inch screw holding the red and black wires in place on the inside of the back cover.
  7. Nextbook 8 Speaker Replacement: 7 단계, 이미지 1/1
    • Remove the two 0.116 inch screws holding the speaker assembly in place.
  8. Nextbook 8 Speaker Replacement: 8 단계, 이미지 1/1
    • Carefully pry the speaker off of the back cover with a spudger.
    • Note: There is glue holding the speaker to the back cover, so it will take some work to get it off.
  9. Nextbook 8 Speaker Replacement: 9 단계, 이미지 1/1
    • Use a desoldering tool to remove the solder holding the red and black speaker wires to the motherboard.
    • If you do not have a desoldering tool, you can use a solder gun to remove the old solder.
    • Caution: Soldering guns get extremely hot.
  10. Nextbook 8 Speaker Replacement: 10 단계, 이미지 1/1
    • Use the soldering gun to solder the new speaker wires to the motherboard where the original wires were connected.
    • Make sure that you connect the red wire to the positive terminal on the right, and the black wire to the negative terminal on the left.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dylan Wiese
회원 가입일: 03/11/15
1,853 평판
안내서 5개 작성하였습니다
Colorado Springs, Team 5-1, Panko Spring 2015 Colorado Springs, Team 5-1, Panko Spring 2015 회원
UCCS-PANKO-S15S5G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 1,333
