주요 콘텐츠로 건너뛰기
Nextbook Flexx 10 Battery Pack Replacement
필요한 것
  1. Nextbook Flexx 10 Battery Pack Replacement, Battery Pack: 1 단계, 이미지 2개 중 1개 Nextbook Flexx 10 Battery Pack Replacement, Battery Pack: 1 단계, 이미지 2개 중 2개
    • To begin, remove the screen from the keyboard.
    • Open the 2-in-1, and hold the screen.
    • Press the silver button at the top of the keyboard.
    • When the screen lifts up, gently lift the screen away from the keyboard.
  2. Nextbook Flexx 10 Battery Pack Replacement: 2 단계, 이미지 3개 중 1개 Nextbook Flexx 10 Battery Pack Replacement: 2 단계, 이미지 3개 중 2개 Nextbook Flexx 10 Battery Pack Replacement: 2 단계, 이미지 3개 중 3개
    • Removing the back cover will invalidate your warranty.
    • You may use your fingers, or a spudger. Be careful not to break your cover OR your fingernail. Removing the cover requires good judgement.
    • The goal is to separate the black from the silver. Start in a corner, or a flat edge -- whichever works best for you. Remember to not use too much force.
    • Once you start the initial separation, keep going until you free one edge. The goal now is to free three edges of the rectangle.
    • If your progress stops on one side of the rectangle, go to the other side and try there.
  3. Nextbook Flexx 10 Battery Pack Replacement: 3 단계, 이미지 1개 중 1개
    • Gently pull the back cover from the screen assembly.
    • Keep the plastic cover close. It's great for holding screws!
    • When putting the cover back on, press firmly around to outside edge with the screen facing down on a flat, debris-free surface.
  4. Nextbook Flexx 10 Battery Pack Replacement: 4 단계, 이미지 1개 중 1개
    • Once you have the cover off, remove the screws from the outer perimeter of the board assembly with a small philips head screwdriver. See arrows.
  5. Nextbook Flexx 10 Battery Pack Replacement: 5 단계, 이미지 3개 중 1개 Nextbook Flexx 10 Battery Pack Replacement: 5 단계, 이미지 3개 중 2개 Nextbook Flexx 10 Battery Pack Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the smaller ribbon clip on the right side of the device and top right of the battery.
    • Remove the second clip underneath the ribbon clip.
  6. Nextbook Flexx 10 Battery Pack Replacement: 6 단계, 이미지 3개 중 1개 Nextbook Flexx 10 Battery Pack Replacement: 6 단계, 이미지 3개 중 2개 Nextbook Flexx 10 Battery Pack Replacement: 6 단계, 이미지 3개 중 3개
    • When removing the second cable clip use a small flat head screw driver to lift the latch.
    • when removing be careful not to damage the ribbon cable.
  7. Nextbook Flexx 10 Battery Pack Replacement: 7 단계, 이미지 2개 중 1개 Nextbook Flexx 10 Battery Pack Replacement: 7 단계, 이미지 2개 중 2개
    • Repeat step 6 for the large ribbon cable.
  8. Nextbook Flexx 10 Battery Pack Replacement: 8 단계, 이미지 3개 중 1개 Nextbook Flexx 10 Battery Pack Replacement: 8 단계, 이미지 3개 중 2개 Nextbook Flexx 10 Battery Pack Replacement: 8 단계, 이미지 3개 중 3개
    • To remove the battery section of the device from the circuit board remove, use the small Phillips head screwdriver for the 3 small screws near the top.
    • To get the battery pack completely away from the circuit board there is copper foil on the back of the battery.
    • be careful not to rip the copper foil. Pull the foil slowly an evenly.
  9. Nextbook Flexx 10 Battery Pack Replacement: 9 단계, 이미지 3개 중 1개 Nextbook Flexx 10 Battery Pack Replacement: 9 단계, 이미지 3개 중 2개 Nextbook Flexx 10 Battery Pack Replacement: 9 단계, 이미지 3개 중 3개
    • Now that the battery is all by itself find a non-sharp and thin object to help pry the battery from its base.
    • Move slowly and carefully to not puncher the battery casing.
    • FINALLY you have successfully removed the battery from your device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jeremiah Fredere
회원 가입일: 10/02/17
171 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 23
전체 시간: 4,742
