주요 콘텐츠로 건너뛰기
Nextbook Flexx 10 Docking Port Replacement
필요한 것
  1. Nextbook Flexx 10 Docking Port Replacement, Back Cover: 1 단계, 이미지 1/2 Nextbook Flexx 10 Docking Port Replacement, Back Cover: 1 단계, 이미지 2/2
    • To begin, turn off the power to the device and remove the screen from the keyboard.
    • Open the 2-in-1, and hold the screen.
    • Press the silver button at the top of the keyboard.
    • When the screen lifts up, gently lift the screen away from the keyboard.
  2. Nextbook Flexx 10 Docking Port Replacement: 2 단계, 이미지 1/3 Nextbook Flexx 10 Docking Port Replacement: 2 단계, 이미지 2/3 Nextbook Flexx 10 Docking Port Replacement: 2 단계, 이미지 3/3
    • You may use your fingers, or a spudger. Be careful not to break your cover OR your fingernail. Removing the cover requires good judgement.
    • The goal is to separate the black from the silver. Start in a corner, or a flat edge -- whichever works best for you. Remember to not use too much force.
    • Once you start the initial separation, keep going until you free one edge. The goal now is to free three edges of the rectangle.
    • If your progress stops on one side of the rectangle, go to the other side and try there.
  3. Nextbook Flexx 10 Docking Port Replacement: 3 단계, 이미지 1/2 Nextbook Flexx 10 Docking Port Replacement: 3 단계, 이미지 2/2
    • Gently pull the back cover from the screen assembly.
    • Keep the plastic cover close. It's great for holding screws!
    • When putting the cover back on, press firmly around to outside edge with the screen facing down on a flat, debris-free surface.
  4. Nextbook Flexx 10 Docking Port Replacement, Docking Port: 4 단계, 이미지 1/2 Nextbook Flexx 10 Docking Port Replacement, Docking Port: 4 단계, 이미지 2/2
    • Now, look around the outer edge in between the two speakers.
    • Locate the docking port
    • Remove the two screws holding the docking port in place with a PH0 philips head screwdriver.
  5. Nextbook Flexx 10 Docking Port Replacement: 5 단계, 이미지 1/1
    • After both screws are removed:
    • Carefully lift the black part of the connector at the board end of the gold cable.
    • Gently pull the gold cable out of the slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Drew Walker
회원 가입일: 09/08/17
134 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 919
