부품
부품은 필요하지 않습니다.
  1. Turn the device over so it is upside-down.
    • Turn the device over so it is upside-down.
  2. Unscrew the 4 screws closest to the screen.
    • Unscrew the 4 screws closest to the screen.
  3. Flip over the device so it is right side up.
    • Flip over the device so it is right side up.
  4. Unscrew the 2 screws on the top of the device, next to the docking plug.
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  6. Take off top piece by using slight force and pulling off.
    • Take off top piece by using slight force and pulling off.
  7. Unscrew the button board with smaller screwdriver.
    • Unscrew the button board with smaller screwdriver.
  8. Lift off the button board.
    • Lift off the button board.
  9. Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  10. Lift the screen vertically straight up.
    • Lift the screen vertically straight up.
      • As you do this the logic board should move off with it.
  11. Flip the screen and the logic board over to the right side.
    • Flip the screen and the logic board over to the right side.
  12. Pull out the white plug that goes from the speakers to the logic board.
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
결론
Michelle Read
회원 가입일: 2012년 09월 26일
1 평판
안내서 1개 작성함
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 회원
CPSU-FORTE-F12S7G50
5 회원들
안내서 8개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 302
