주요 콘텐츠로 건너뛰기
Nextplay NP109CR Speakers Replacement
필요한 것
  1. Nextplay NP109CR Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Turn the device over so it is upside-down.
  2. Nextplay NP109CR Speakers Replacement: 2 단계, 이미지 1/1
    • Unscrew the 4 screws closest to the screen.
  3. Nextplay NP109CR Speakers Replacement: 3 단계, 이미지 1/1
    • Flip over the device so it is right side up.
  4. Nextplay NP109CR Speakers Replacement: 4 단계, 이미지 1/1
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Nextplay NP109CR Speakers Replacement: 5 단계, 이미지 1/1
    • Take off top piece by using slight force and pulling off.
  6. Nextplay NP109CR Speakers Replacement: 6 단계, 이미지 1/1
    • Unscrew the button board with smaller screwdriver.
  7. Nextplay NP109CR Speakers Replacement: 7 단계, 이미지 1/1
    • Lift off the button board.
  8. Nextplay NP109CR Speakers Replacement: 8 단계, 이미지 1/1
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  9. Nextplay NP109CR Speakers Replacement: 9 단계, 이미지 1/1
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  10. Nextplay NP109CR Speakers Replacement: 10 단계, 이미지 1/1
    • Flip the screen and the logic board over to the right side.
  11. Nextplay NP109CR Speakers Replacement: 11 단계, 이미지 1/1
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
결론
Michelle Read
회원 가입일: 09/26/12
1 평판
안내서 1개 작성함
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 회원
CPSU-FORTE-F12S7G50
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 390
