주요 콘텐츠로 건너뛰기
Nexus 10 Display Replacement
필요한 것
  1. Nexus 10 Display Replacement, Battery: 1 단계, 이미지 3개 중 1개 Nexus 10 Display Replacement, Battery: 1 단계, 이미지 3개 중 2개 Nexus 10 Display Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 Display Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 Display Replacement: 3 단계, 이미지 3개 중 1개 Nexus 10 Display Replacement: 3 단계, 이미지 3개 중 2개 Nexus 10 Display Replacement: 3 단계, 이미지 3개 중 3개
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  4. Nexus 10 Display Replacement: 4 단계, 이미지 3개 중 1개 Nexus 10 Display Replacement: 4 단계, 이미지 3개 중 2개 Nexus 10 Display Replacement: 4 단계, 이미지 3개 중 3개
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
  5. Nexus 10 Display Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 Display Replacement: 6 단계, 이미지 2개 중 1개 Nexus 10 Display Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
  7. Nexus 10 Display Replacement, Headphone Jack: 7 단계, 이미지 1개 중 1개
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 Display Replacement: 8 단계, 이미지 3개 중 1개 Nexus 10 Display Replacement: 8 단계, 이미지 3개 중 2개 Nexus 10 Display Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 Display Replacement: 9 단계, 이미지 3개 중 1개 Nexus 10 Display Replacement: 9 단계, 이미지 3개 중 2개 Nexus 10 Display Replacement: 9 단계, 이미지 3개 중 3개
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 Display Replacement: 10 단계, 이미지 2개 중 1개 Nexus 10 Display Replacement: 10 단계, 이미지 2개 중 2개
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 Display Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 Display Replacement: 12 단계, 이미지 2개 중 1개 Nexus 10 Display Replacement: 12 단계, 이미지 2개 중 2개
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
  13. Nexus 10 Display Replacement: 13 단계, 이미지 2개 중 1개 Nexus 10 Display Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 Display Replacement: 14 단계, 이미지 2개 중 1개 Nexus 10 Display Replacement: 14 단계, 이미지 2개 중 2개
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
  15. Nexus 10 Display Replacement, Display: 15 단계, 이미지 2개 중 1개 Nexus 10 Display Replacement, Display: 15 단계, 이미지 2개 중 2개
    • Detach LCD connector ribbon by pressing upward on connector latch using a plastic opening tool.
  16. Nexus 10 Display Replacement: 16 단계, 이미지 2개 중 1개 Nexus 10 Display Replacement: 16 단계, 이미지 2개 중 2개
    • Unscrew the two 2mm Phillips #00 screws holding the ribbon in place.
    • Remove the board by tilting it forward and pulling outward.
  17. Nexus 10 Display Replacement: 17 단계, 이미지 1개 중 1개
    • Remove second speaker by gently tilting and pulling upward.
  18. Nexus 10 Display Replacement: 18 단계, 이미지 3개 중 1개 Nexus 10 Display Replacement: 18 단계, 이미지 3개 중 2개 Nexus 10 Display Replacement: 18 단계, 이미지 3개 중 3개
    • Unscrew the two 2mm screws securing the micro HDMI connector with a #PH00 screwdriver.
    • Remove the connector by liberally applying upward pressure.
  19. Nexus 10 Display Replacement: 19 단계, 이미지 3개 중 1개 Nexus 10 Display Replacement: 19 단계, 이미지 3개 중 2개 Nexus 10 Display Replacement: 19 단계, 이미지 3개 중 3개
    • Unscrew the 2mm Phillips #00 screw that holds the flash enclosure.
    • Remove the flash assembly with a plastic opening tool by lifting the assembly upward.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Benjamin Troller
회원 가입일: 04/11/16
2,218 평판
안내서 5개를 작성함
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 회원
CPSU-MANESS-S16S34G18
4 회원들
안내서 5개를 작성함
4가이드 댓글
I’m waiting for the instructions regarding how to remove the old screen and insert the new - it seems to be missing
John Walker - 답글
It seems you just have to buy a replacement for that whole front housing, including the screen assembly
Oliver Nichol -
Still waiting to see how the screen is remove
Frank - 답글
he cambiado la bateria y he partido el presor negro del conector de LCD y no me me funciona, se puede comprar esa pieza negra?
Diego Mera - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 46
전체 시간: 8,652
