주요 콘텐츠로 건너뛰기
Nexus 10 Front Facing Camera Replacement
필요한 것
  1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: 1 단계, 이미지 1/3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: 1 단계, 이미지 2/3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: 1 단계, 이미지 3/3
    • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
  2. Nexus 10 Front Facing Camera Replacement: 2 단계, 이미지 1/3 Nexus 10 Front Facing Camera Replacement: 2 단계, 이미지 2/3 Nexus 10 Front Facing Camera Replacement: 2 단계, 이미지 3/3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  3. Nexus 10 Front Facing Camera Replacement: 3 단계, 이미지 1/3 Nexus 10 Front Facing Camera Replacement: 3 단계, 이미지 2/3 Nexus 10 Front Facing Camera Replacement: 3 단계, 이미지 3/3
    • Lift latch on front-facing camera connector.
    • Pull the connector toward the top of the device and remove the front-facing camera.
결론
Benjamin Troller
회원 가입일: 04/11/16
2,181 평판
안내서 5개 작성하였습니다
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 회원
CPSU-MANESS-S16S34G18
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 583
