주요 콘텐츠로 건너뛰기
Nexus 10 Headphone Jack Replacement
필요한 것
  1. Nexus 10 Headphone Jack Replacement, Battery: 1 단계, 이미지 1/3 Nexus 10 Headphone Jack Replacement, Battery: 1 단계, 이미지 2/3 Nexus 10 Headphone Jack Replacement, Battery: 1 단계, 이미지 3/3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 Headphone Jack Replacement: 3 단계, 이미지 1/3 Nexus 10 Headphone Jack Replacement: 3 단계, 이미지 2/3 Nexus 10 Headphone Jack Replacement: 3 단계, 이미지 3/3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  4. Nexus 10 Headphone Jack Replacement: 4 단계, 이미지 1/3 Nexus 10 Headphone Jack Replacement: 4 단계, 이미지 2/3 Nexus 10 Headphone Jack Replacement: 4 단계, 이미지 3/3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
  5. Nexus 10 Headphone Jack Replacement: 5 단계, 이미지 1/1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 Headphone Jack Replacement: 6 단계, 이미지 1/2 Nexus 10 Headphone Jack Replacement: 6 단계, 이미지 2/2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
  7. Nexus 10 Headphone Jack Replacement, Headphone Jack: 7 단계, 이미지 1/1
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 Headphone Jack Replacement: 8 단계, 이미지 1/3 Nexus 10 Headphone Jack Replacement: 8 단계, 이미지 2/3 Nexus 10 Headphone Jack Replacement: 8 단계, 이미지 3/3
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 Headphone Jack Replacement: 9 단계, 이미지 1/3 Nexus 10 Headphone Jack Replacement: 9 단계, 이미지 2/3 Nexus 10 Headphone Jack Replacement: 9 단계, 이미지 3/3
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 Headphone Jack Replacement: 10 단계, 이미지 1/2 Nexus 10 Headphone Jack Replacement: 10 단계, 이미지 2/2
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 Headphone Jack Replacement: 11 단계, 이미지 1/1
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 Headphone Jack Replacement: 12 단계, 이미지 1/2 Nexus 10 Headphone Jack Replacement: 12 단계, 이미지 2/2
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
  13. Nexus 10 Headphone Jack Replacement: 13 단계, 이미지 1/2 Nexus 10 Headphone Jack Replacement: 13 단계, 이미지 2/2
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 Headphone Jack Replacement: 14 단계, 이미지 1/2 Nexus 10 Headphone Jack Replacement: 14 단계, 이미지 2/2
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
결론
Benjamin Troller
회원 가입일: 04/11/16
2,181 평판
안내서 5개 작성하였습니다
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 회원
CPSU-MANESS-S16S34G18
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 720
