주요 콘텐츠로 건너뛰기
Nexus 10 USB Port Replacement
필요한 것
  1. Nexus 10 USB Port Replacement, Battery: 1 단계, 이미지 3개 중 1개 Nexus 10 USB Port Replacement, Battery: 1 단계, 이미지 3개 중 2개 Nexus 10 USB Port Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 USB Port Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 USB Port Replacement: 3 단계, 이미지 3개 중 1개 Nexus 10 USB Port Replacement: 3 단계, 이미지 3개 중 2개 Nexus 10 USB Port Replacement: 3 단계, 이미지 3개 중 3개
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  4. Nexus 10 USB Port Replacement: 4 단계, 이미지 3개 중 1개 Nexus 10 USB Port Replacement: 4 단계, 이미지 3개 중 2개 Nexus 10 USB Port Replacement: 4 단계, 이미지 3개 중 3개
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
  5. Nexus 10 USB Port Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 USB Port Replacement: 6 단계, 이미지 2개 중 1개 Nexus 10 USB Port Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
  7. Nexus 10 USB Port Replacement, Headphone Jack: 7 단계, 이미지 1개 중 1개
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 USB Port Replacement: 8 단계, 이미지 3개 중 1개 Nexus 10 USB Port Replacement: 8 단계, 이미지 3개 중 2개 Nexus 10 USB Port Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 USB Port Replacement: 9 단계, 이미지 3개 중 1개 Nexus 10 USB Port Replacement: 9 단계, 이미지 3개 중 2개 Nexus 10 USB Port Replacement: 9 단계, 이미지 3개 중 3개
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 USB Port Replacement: 10 단계, 이미지 2개 중 1개 Nexus 10 USB Port Replacement: 10 단계, 이미지 2개 중 2개
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 USB Port Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 USB Port Replacement: 12 단계, 이미지 2개 중 1개 Nexus 10 USB Port Replacement: 12 단계, 이미지 2개 중 2개
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
  13. Nexus 10 USB Port Replacement: 13 단계, 이미지 2개 중 1개 Nexus 10 USB Port Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 USB Port Replacement: 14 단계, 이미지 2개 중 1개 Nexus 10 USB Port Replacement: 14 단계, 이미지 2개 중 2개
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Benjamin Troller
회원 가입일: 04/11/16
2,218 평판
안내서 5개를 작성함
Cal Poly, Team 34-18, Maness Spring 2016 Cal Poly, Team 34-18, Maness Spring 2016 회원
CPSU-MANESS-S16S34G18
4 회원들
안내서 5개를 작성함
1가이드 댓글
Perfect guide, I managed to fix my Nexus 10 broken usb port.
It may be worth to mention after step 14 you need to gently remove the plastic connectors cover and place it on the replacement part.
Mauri - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 19
전체 시간: 5,950
