주요 콘텐츠로 건너뛰기
Nexus 4 Audio Jack Replacement
필요한 것
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  1. Nexus 4 Audio Jack Replacement: 3 단계, 이미지 1/3 Nexus 4 Audio Jack Replacement: 3 단계, 이미지 2/3 Nexus 4 Audio Jack Replacement: 3 단계, 이미지 3/3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  2. Nexus 4 Audio Jack Replacement, Battery: 4 단계, 이미지 1/2 Nexus 4 Audio Jack Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  3. Nexus 4 Audio Jack Replacement, Plastic Midframe: 6 단계, 이미지 1/3 Nexus 4 Audio Jack Replacement, Plastic Midframe: 6 단계, 이미지 2/3 Nexus 4 Audio Jack Replacement, Plastic Midframe: 6 단계, 이미지 3/3
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
  4. Nexus 4 Audio Jack Replacement, Audio Jack: 7 단계, 이미지 1/3 Nexus 4 Audio Jack Replacement, Audio Jack: 7 단계, 이미지 2/3 Nexus 4 Audio Jack Replacement, Audio Jack: 7 단계, 이미지 3/3
    • Using a spudger, pop off the gray connector on the top right of the motherboard.
  5. Nexus 4 Audio Jack Replacement: 8 단계, 이미지 1/3 Nexus 4 Audio Jack Replacement: 8 단계, 이미지 2/3 Nexus 4 Audio Jack Replacement: 8 단계, 이미지 3/3
    • Gently lift the audio jack upwards and to the left to remove it from the motherboard.
  6. Nexus 4 Audio Jack Replacement: 9 단계, 이미지 1/2 Nexus 4 Audio Jack Replacement: 9 단계, 이미지 2/2
    • The audio port will likely lift out together with the ambient light sensor rubber cap.
    • Remove the cap from the old part and move it to the new one. Ensure the cap stays in place when installing the new audio port into the phone.
결론
다른 26명이 해당 안내서를 완성하였습니다.
Kaitlyn Jones
회원 가입일: 01/27/13
4,952 평판
안내서 8개 작성하였습니다
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013 회원
CPSU-AMIDO-W13S3G32
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
where can I order the original connector on my Nexus 4? With delivery to the Crimea.
Grateful for the answer in advance.
Konstantin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 22,952
