이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
이 단계에 사용된 도구:SIM Card Eject Tool$2.99-
Power off the phone, by long-pressing the power button and touching Power off.
Remove the SIM tray using the SIM Card Eject Tool.
이 단계에 사용된 도구:T5 Torx Screwdriver$5.49-
Remove the two screws from the bottom of the phone with a T5 Torx Screwdriver.
Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
다른 48명이 해당 안내서를 완성하였습니다.
댓글 3개
I have made some rearrangement at this guide:
It more logic to remove the tray before removing the screws.
I have used some pictures from the teardown to clarify, particularly for showing the inside of the Nexus 4 showing the battery installed. The original picture did not show the battery. I have also made better reference to the tools.
I ordered the back case using the provided link at etradesupply.com, and noticed it is not an original part: the wireless charging does not work at all (the coil has a much higher resistance than the original one). After insisting, they sent me another one, which gave the same result. Better avoid buying there if you expect original working products...
What about the buttons and the NFC? I can buy a back cover with NFC included, but most seem to not have the buttons. Is it easy to remove the ones from the old cover and install them in the new cover?
Martin Fei - 답글
