주요 콘텐츠로 건너뛰기
Nexus 4 Plastic Midframe Replacement
필요한 것
  1. Nexus 4 Plastic Midframe Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Nexus 4 Plastic Midframe Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    SIM Card Eject Tool
    $2.99
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Plastic Midframe Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
  3. Nexus 4 Plastic Midframe Replacement: 3 단계, 이미지 3개 중 1개 Nexus 4 Plastic Midframe Replacement: 3 단계, 이미지 3개 중 2개 Nexus 4 Plastic Midframe Replacement: 3 단계, 이미지 3개 중 3개
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Plastic Midframe Replacement, Battery: 4 단계, 이미지 2개 중 1개 Nexus 4 Plastic Midframe Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
  5. Nexus 4 Plastic Midframe Replacement, Battery removal: 5 단계, 이미지 2개 중 1개 Nexus 4 Plastic Midframe Replacement, Battery removal: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  6. Nexus 4 Plastic Midframe Replacement, Plastic Midframe: 6 단계, 이미지 3개 중 1개 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: 6 단계, 이미지 3개 중 2개 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: 6 단계, 이미지 3개 중 3개
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Kaitlyn Jones
회원 가입일: 01/27/13
4,964 평판
안내서 8개를 작성함
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013 회원
CPSU-AMIDO-W13S3G32
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 17
전체 시간: 11,214
