주요 콘텐츠로 건너뛰기
Nexus 5 Antenna Cable Replacement
필요한 것
  1. Nexus 5 Antenna Cable Replacement, Remove the Battery Door: 1 단계, 이미지 1개 중 1개
    • The battery door of the Nexus 5 is held together with plastic clips.
    • Use the plastic spudger to separate the battery door.
  2. Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: 2 단계, 이미지 3개 중 1개 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: 2 단계, 이미지 3개 중 2개 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: 2 단계, 이미지 3개 중 3개
    • Using your #00 Philips Screwdriver, remove the six screws holding the midframe in place.
    • Remove the four screws at the bottom of the device holding the speaker assembly in place.
    • The screw on the far right may be covered in adhesive. Use your plastic spudger to remove the adhesive covering the screw.
  3. Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: 3 단계, 이미지 2개 중 1개 Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: 3 단계, 이미지 2개 중 2개
    • Remove the midframe and speaker assembly.
  4. Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: 4 단계, 이미지 3개 중 1개 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: 4 단계, 이미지 3개 중 2개 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: 4 단계, 이미지 3개 중 3개
    • The antenna cables are located on the right and left side of the battery (one is gray, the other is black).
    • Using your plastic spudger, disconnect both ends of the antenna cables.
    • Connect your new antenna cables.
    • Make sure the antenna cables are securely connected.
  5. Nexus 5 Antenna Cable Replacement, Reassemble the Device: 5 단계, 이미지 2개 중 1개 Nexus 5 Antenna Cable Replacement, Reassemble the Device: 5 단계, 이미지 2개 중 2개
    • Screw the midframe and speaker assembly back into place.
    • Push the outer edges of the battery door down until you hear the plastic clips "click."
    • Hold the power button until you feel the phone vibrate and/or see the Google logo displayed.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tyler Caldwell
회원 가입일: 12/07/17
184 평판
안내서 1개를 작성함
IUPUI, Team S1-G1, Baechle Fall 2017 IUPUI, Team S1-G1, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S1G1
2 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 20
전체 시간: 3,028
