주요 콘텐츠로 건너뛰기
Nexus 5 Loudspeaker Replacement
필요한 것
  1. Nexus 5 Loudspeaker Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Nexus 5 Loudspeaker Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Nexus 5 Loudspeaker Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to free the clips on the top and each side of the back cover.
    • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
    • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
    • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
  2. Nexus 5 Loudspeaker Replacement, Loudspeaker: 2 단계, 이미지 2개 중 1개 Nexus 5 Loudspeaker Replacement, Loudspeaker: 2 단계, 이미지 2개 중 2개
    • Remove the four Phillips #00 screws that secure the speaker assembly.
    • Use a plastic opening tool to gently pry the speaker assembly out of the phone.
결론
다른 18명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chris Willis
회원 가입일: 10/03/14
1,371 평판
안내서 3개를 작성함
USF Tampa, Team 13-4, Staggers Fall 2014 USF Tampa, Team 13-4, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G4
3 회원들
안내서 13개를 작성함
댓글 한 개
Fantastic! My speaker assembly from iFixit arrived today, and about 20 minutes later I'd just saved myself the $600 dolalrs of buying a new phone. Great site, thanks guys!
Charles Comenos - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 13
전체 시간: 22,033
