주요 콘텐츠로 건너뛰기
Nexus 5 Motherboard Replacement
필요한 것
  1. Nexus 5 Motherboard Replacement, SIM Card: 1 단계, 이미지 2개 중 1개 Nexus 5 Motherboard Replacement, SIM Card: 1 단계, 이미지 2개 중 2개
    • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
    • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
    • Push the tool into the hole until you see the card pop out.
  2. Nexus 5 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
    • Make sure the chip is facing the rear of the phone when reinserting the SIM card.
  3. Nexus 5 Motherboard Replacement, Back Cover: 3 단계, 이미지 3개 중 1개 Nexus 5 Motherboard Replacement, Back Cover: 3 단계, 이미지 3개 중 2개 Nexus 5 Motherboard Replacement, Back Cover: 3 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to free the clips on the top and each side of the back cover.
    • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
    • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
    • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
    Wireless QI and NFC.
    Once I have put everything together with the new battery in place, I have as last replaced the plastic back cover, snapping all the clips back around the edges of the phone. Alas, I was quick to realise the QI Wireless charging has ceased to work.
    I almost blamed the battery, or worse, me.
    QUICK TIP: there is actually another clip in the middle of the plastic back cover - just press with your thumb just above the 'S' in NEXUS emblem and, voila! Snaps back in.
    Wireless charge and NFC - works, once again.
    cwioro - 답글
    you just saved me like 30 bucks. thank you so much.
    Robert Nolan -
    + 1, had the same issue and pressing just near the S fixed it! Thanks a lot!
    nicco82 -
    Just a me too, I had to press above the S and it was quite a snap
    Erik Karlin -
    There seems to be two contacts that snap into place. One is in line with the led pretty much in the middle of the phone and the second one in line with the camera lens on the opposite side to the lens. The middle one for me snapped pretty lightly, but the side one required a bit more pressure. After that the nfc started working again. Thanks for posting this!
    Dennis Millner -
    Is it hard to remove the battery door? Worried I might damage it.
    Ash - 답글
    When I openend the back cover I damaged two clips. One about 2.5cm (1 inch) below the volume controls and one on the other side about same height. The cover fits good without those two but on one side there is a small gap where the clip broke. But I have a hard cover protector on my phone so it's not that bad.
    simonlwheeler - 답글
    The case around the sim slot is pretty thin and easy to break, best to avoid using the pry tool at this point.
    Aled Morris - 답글
    Excellent tip, should be included in the main guide.
    fprades - 답글
    Hey Author, i need to ur expert advice...i replaced my nexus 5's back cover. since the new one did not have the vibrators battery i had to take it from the old one and connect it to the new one...on removing i noticed that it was stuck to the cover by a glue
    Question: what glue to use to hold the battery to the cover?
    suwaid akbar - 답글
    Any adhesive will do. I used a hot glue gun. You shouldn't need expert advice to figure that out. Use your head.
    tjt263 -
    The case around the volume control is also pretty thin.... I broke mine prying so avoid the pry there too.
    Also my back had glue at the bottom and I haven't seen mentioned
    kornerson - 답글
  4. Nexus 5 Motherboard Replacement, Midframe: 4 단계, 이미지 1개 중 1개
    • Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
    • Ensure you retain all six of the 4.0mm screws! These hold the midframe securely and closely to the motherboard. The three small snaps on the back cover that attach to the midframe ensure the NFC antenna and wireless charging coil connectors contact securely with the motherboard, and work reliably.
    • To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
    I had a bit more success with the Phillips #000.
    Ross Light - 답글
    Step 4 (removing the screws in the protecting plate) needs to happen before Step 2 ( removing the connectors)
    Esteban Valles - 답글
    These were Y0 screws for me.
    Benjamin Hollway - 답글
    Same here, Benjamin
    Ítalo Masserano -
    Me three on the Y-type screw heads.
    Jamoross -
    Same for me. I had more luck with the two screws in the middle with #000.
    Rewarp - 답글
  5. Nexus 5 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Nexus 5 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the midframe from the phone.
    • Examine the midframe and the back cover and you'll find three very small snap attachment points for the back to the midframe. These ensure that the NFC and wireless charging antenna contacts connect with the corresponding spring connectors on the motherboard. Ensure the snaps are in good condition.
    There's also some adhesive holding the motherboard cover plate in place, below the camera. Has to be pulled a little stronger than expected.
    tkatona - 답글
  6. Nexus 5 Motherboard Replacement, Battery: 6 단계, 이미지 2개 중 1개 Nexus 5 Motherboard Replacement, Battery: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $2.99
    • Use the flat end of a nylon spudger to disconnect the battery connector.
  7. Nexus 5 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Nexus 5 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the daughterboard ribbon cable and pull it away from the battery.
  8. Nexus 5 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Nexus 5 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Nexus 5 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to pry the battery out of its housing.
    • You may need to use a heat gun to apply a small amount of heat to soften the adhesive below the battery.
    • Do not puncture or bend the battery.
    • If replacing the battery, bag the old battery up and recycle responsibly at a suitable location.
    This part is very delicate. The adhesive is pretty solid and I did puncture the battery. It is dangerous and the battery should be replaced with a new one.
    Christophe De Wolf - 답글
    Thanks Chris for the notice. I have added a warning on your advise. Do you think about any better way to unglue the battery?
    Gaetan -
    Like another user, I had already taken my cover off plenty of times prior to. The issue of course was removing the battery. I purchased the opening tools and spudger and used them but to no avail. I ended up using a flat tip screwdriver and got the battery out within seconds with no puncturing.
    gnewton16 - 답글
    I'll second the flathead screwdriver. Tried different plastic tools only to damage both the battery and a spring connector on the phone. With the flathead screwdriver battery came out quite easily lifting from the bottom end. There is an adhesive tape holding the battery firmly in place that retains the adhesive surface after removing the battery, so the new battery should attach properly.
    Dennis Millner -
    Why do you need to remove the battery at all? Just replaced my rear camera without removing it. I mean, I realise that removing the power source would have been safer, but would it be enough just to detach the motherboard connector?
    eyusupov - 답글
    This guide is about the REPLACEMENT of the battery, and for that it seems necessary to remove it first. ;-)
    biharikristof -
    Do you need to apply adhesive to the new battery to keep it in place?
    Ross Light - 답글
    no there is generally glue remaining and it stays in place pretty good
    mmoodley10 -
    This was fantastic, thank you! I had never done anything like this before! You just saved me some money and also taught me something :D
    anagarciasebastia - 답글
    to make Qi work, you have to press the cover really everywhere afterwards. The contacts for Qi are between th Nexus "S" and the camera. Sometimes the Qi loading needs some time to work - I assume the battery needs to expand after a few loading cycles...
    Apeiron - 답글
    The first time I tried to replace the battery I ended up breaking off the tab on the new battery. It needs to be bent properly to fit into the socket on the phone. The second time, I connected the tab t the socket BEFORE placing the new battery into the area of the phone where it sits. Then I was able to use the plastic tool to correctly bend the connector.
    John Goldin - 답글
    I have replaced the battery and after doing this there is a flashing red light. does this mean its just charging from empty or have I done something wrong? Do i need to press any buttons to make sure its charging properly? do i need to re open it up to check connections? what do i do? there is no mention of whether it should turn back on or what it should do/how long it will take to be up and running again.
    Bambipeach - 답글
    I had the same "problem", though I had misplugged the battery. Just wait for a couple of minutes and your phone should start to charge. Also, I've been told to fully charge and discharge the battery 2-3 times before using it.
    Steve Simard -
    Be extremely careful while prying out the battery. I had damaged a Nexus 4 battery while trying to do this, and smoke started coming out. If you search youtube you can see how a punctured Li-ion battery can explode in seconds.
    Abhi B - 답글
    Why not remove the battery by pulling on the small ribbon cable at the top?
    Matt Szczublewski - 답글
    When you take out the battery, there are some sort of black tape (adhesive) around the inner circle of the empty battery chassis. I might have been too rough and taken the black tape out completely. Now with the newly replaced battery, Nexus 5 won't charge or power on. Does anyone know what the black tape is for? is it the reason or something else?
    Gracie - 답글
    I found out that the heavy duty suction cup I bought to replace phone screens works quite effectively at removing the battery without bending or damaging it. Of course, this was being used on a battery that was itself a replacement of the original, so the adhesive may have weakened significantly.
    Rewarp - 답글
  9. Nexus 5 Motherboard Replacement, Motherboard: 9 단계, 이미지 2개 중 1개 Nexus 5 Motherboard Replacement, Motherboard: 9 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the left antenna cable.
  10. Nexus 5 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Nexus 5 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the right antenna cable.
    • These must be firmly secured during reassembly. Failure to secure the antenna connections will affect your reception and call quality.
  11. Nexus 5 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Nexus 5 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the ribbon cable that connects rear-facing camera to the motherboard.
  12. Nexus 5 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Nexus 5 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the front camera ribbon cable.
  13. Nexus 5 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Nexus 5 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Gently lift the motherboard up and out of the device.
결론
다른 31명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Kyle Libby
회원 가입일: 04/07/14
1,006 평판
안내서 7개를 작성함
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014 회원
CPSU-REGAN-S14S7G23
4 회원들
안내서 19개를 작성함
댓글 12개
is the motherboard from the 32gb nexus 5, compatible for the nexus 5 16gb lcd??
Vandalismo Teevee - 답글
It should be, yes. I've chopped and changed loads of Nexus 5 phone around and haven't had a problem.
drunkenmenace -
Thanks for the repy. My Nexus 5 has some bootoop problems and when i go to the boot options, (the hold power and volume down), it says Lock State - LOCKED. so im thinking of replacing the motherboard. or is there a way to fix my problem? Thanks for the reply. I appreciate it.
My Nexus 5 just switched off while i was recording a video. It isnt switching on now. How to bring it back to life??Any solution will b of great help. Thanks
Jasmine K - 답글
I just used this guide to quickly get at the motherboard to replace a faulty power button. It's tedious but not impossible with a very clean soldering iron tip, solder wick, and lots of flux. The replacement button and covers from iFixit were an exact match (I checked under a microscope).
Mark Renouf - 답글
Tip: You do not need to remove the battery to swap or repair the motherboard. I prefer not to use a heatgun and pry against adhesives unless absolutely necessary.
Mark Renouf - 답글
Pls my nexus 5x stopped working since January and I tried charging but any time I fix the battery it will be v.hot till I remove d battery, any help pls.
Abdul Jelil Badmus - 답글
If I replace the motherboard do I have to flash OS ?
MrSavedby Grace - 답글
I will want mother board of lg nexus 5x, 32 gb, how can i buy it
Hildegarde Cyril - 답글
Hello every one My nexus 5 LG screen was damaged and replaced. after a few days the phone died. the repair man told me its motherboard must be repalced to return it to life. Please help me how to get one here Nairobi. They are not available. Kindly help
mutindirose - 답글
I have problem with the WiFi in my Nexus 5
is just stuck on turning on and it doesn't and Mac address disappeared I tried software solutions but doesn't work so what is the problem should I exchange the motherboard chip ?
ammar basha - 답글
Is there any way to salvage photos from the memory if you have to change the motherboard? I changed the battery but the phone still does not turn on. When I plug it into the USB the computer says the device malfunctioned. So it knows something is there...but not working properly
Esp Ghia - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 8
지난 30일: 42
전체 시간: 35,575
