주요 콘텐츠로 건너뛰기
Nexus 5X Rear Panel Replacement
필요한 것
  1. Nexus 5X Rear Panel Replacement, SIM Card Tray: 1 단계, 이미지 1/3 Nexus 5X Rear Panel Replacement, SIM Card Tray: 1 단계, 이미지 2/3 Nexus 5X Rear Panel Replacement, SIM Card Tray: 1 단계, 이미지 3/3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Rear Panel Replacement, Rear Panel: 2 단계, 이미지 1/3 Nexus 5X Rear Panel Replacement, Rear Panel: 2 단계, 이미지 2/3 Nexus 5X Rear Panel Replacement, Rear Panel: 2 단계, 이미지 3/3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Nexus 5X Rear Panel Replacement: 3 단계, 이미지 1/3 Nexus 5X Rear Panel Replacement: 3 단계, 이미지 2/3 Nexus 5X Rear Panel Replacement: 3 단계, 이미지 3/3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Rear Panel Replacement: 4 단계, 이미지 1/2 Nexus 5X Rear Panel Replacement: 4 단계, 이미지 2/2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
결론
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
다른 26명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
201,069 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 16,573개 작성하였습니다
댓글 한 개
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
Lucas Marti - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 8,701
