소개
The rear facing camera can be replaced after the phone's casing has been separated. Use the Troubleshooting Guide to make sure this is the correct solution.
필요한 것
With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
Remove the SIM card and the SIM card holder.
이 단계에 사용된 도구:iOpener$12.99
Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
Pry open the back casing using the soft plastic opening pick.
Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
With tweezers, remove the rubber protector on the lower part of the phone.
Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
Use the spudger to release the rear facing camera connector.
Use tweezers to gently remove the rear facing camera.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
Even though I followed the guide, step by step, and heeded all the advice, once reassembled I cannot get the phone to restart.
check the power and volume ribbon cable and the connector at the top left of the device, it could be loose..
I had the same problem. But it resolved itself when I connected the charger to the phone.
