주요 콘텐츠로 건너뛰기
Nexus 6P Rear Camera Replacement
필요한 것
  1. Nexus 6P Rear Camera Replacement, Back Cover: 1 단계, 이미지 1/3 Nexus 6P Rear Camera Replacement, Back Cover: 1 단계, 이미지 2/3 Nexus 6P Rear Camera Replacement, Back Cover: 1 단계, 이미지 3/3
    • It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair.
    • Use a SIM card eject tool, to pop out and remove the SIM card tray.
    • Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
  2. Nexus 6P Rear Camera Replacement: 2 단계, 이미지 1/3 Nexus 6P Rear Camera Replacement: 2 단계, 이미지 2/3 Nexus 6P Rear Camera Replacement: 2 단계, 이미지 3/3
    • The knife is really sharp. Take care, not to cut yourself or your phone.
    • Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
    • Slide the opening pick underneath the plastic cover to cut the adhesive.
  3. Nexus 6P Rear Camera Replacement: 3 단계, 이미지 1/2 Nexus 6P Rear Camera Replacement: 3 단계, 이미지 2/2
    • Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
    • Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
  4. Nexus 6P Rear Camera Replacement: 4 단계, 이미지 1/3 Nexus 6P Rear Camera Replacement: 4 단계, 이미지 2/3 Nexus 6P Rear Camera Replacement: 4 단계, 이미지 3/3
    • Glass may break. Wear protective glasses and protective gloves.
    • Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
    • Pry off the glass cover.
  5. Nexus 6P Rear Camera Replacement: 5 단계, 이미지 1/3 Nexus 6P Rear Camera Replacement: 5 단계, 이미지 2/3 Nexus 6P Rear Camera Replacement: 5 단계, 이미지 3/3
    • Remove the six Phillips #00 screws.
    • Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
  6. Nexus 6P Rear Camera Replacement: 6 단계, 이미지 1/3 Nexus 6P Rear Camera Replacement: 6 단계, 이미지 2/3 Nexus 6P Rear Camera Replacement: 6 단계, 이미지 3/3
    • Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
    • The knife is really sharp, be careful, not to cut yourself or your phone.
    • Insert a second opening pick and slide it to the top left corner.
    • Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
    • Remove the rear cover.
  7. Nexus 6P Rear Camera Replacement, Rear Camera: 7 단계, 이미지 1/3 Nexus 6P Rear Camera Replacement, Rear Camera: 7 단계, 이미지 2/3 Nexus 6P Rear Camera Replacement, Rear Camera: 7 단계, 이미지 3/3
    • Remove the six Phillips #000 screws.
    • Use tweezers to remove the metal shields covering the battery/main flex cable and the display flex cable.
  8. Nexus 6P Rear Camera Replacement: 8 단계, 이미지 1/3 Nexus 6P Rear Camera Replacement: 8 단계, 이미지 2/3 Nexus 6P Rear Camera Replacement: 8 단계, 이미지 3/3
    • Unplug the antenna cable with tweezers.
    • Use a spudger to disconnect the display and battery flex cable.
  9. Nexus 6P Rear Camera Replacement: 9 단계, 이미지 1/3 Nexus 6P Rear Camera Replacement: 9 단계, 이미지 2/3 Nexus 6P Rear Camera Replacement: 9 단계, 이미지 3/3
    • Use a spudger to disconnect the main flex cable.
    • Pry up the motherboard with a spudger until you can get a good grip.
  10. Nexus 6P Rear Camera Replacement: 10 단계, 이미지 1/3 Nexus 6P Rear Camera Replacement: 10 단계, 이미지 2/3 Nexus 6P Rear Camera Replacement: 10 단계, 이미지 3/3
    • The front facing camera and the headphone jack are still connected to the motherboard. Don't damage them while removing the motherboard.
    • Remove the motherboard carefully.
    • Flip the motherboard and disconnect the rear camera flex cable with a spudger.
    • Carefully remove the rear camera with tweezers.
결론
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
203,329 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
Any suggestions on where to source adhesive or what to use?
Sylvester Jakubowski - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 1,478
