주요 콘텐츠로 건너뛰기
소개
Use this guide to replace the vibration motor in your Nexus 6P smartphone. When reassembling your phone apply new adhesive where it is necessary.
  1. It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair. Use a SIM card eject tool, to pop out and remove the SIM card tray. Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
    • It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair.
    • Use a SIM card eject tool, to pop out and remove the SIM card tray.
    • Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
  2. The knife is really sharp. Take care, not to cut yourself or your phone. Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick. Slide the opening pick underneath the plastic cover to cut the adhesive.
    • The knife is really sharp. Take care, not to cut yourself or your phone.
    • Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
    • Slide the opening pick underneath the plastic cover to cut the adhesive.
  3. Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone. Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
    • Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
    • Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
  4. Glass may break. Wear protective glasses and protective gloves. Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath. Pry off the glass cover.
    • Glass may break. Wear protective glasses and protective gloves.
    • Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
    • Pry off the glass cover.
  5. 안드로이드 수리 키트
    A new screen or battery is one kit away.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  6. Remove the six Phillips #00 screws. Use tweezers to remove any stickers covering the screw to allow better seating for the driver. Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
    • Remove the six Phillips #00 screws.
    • Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
  7. Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner. The knife is really sharp, be careful, not to cut yourself or your phone. Insert a second opening pick and slide it to the top left corner.
    • Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
    • The knife is really sharp, be careful, not to cut yourself or your phone.
    • Insert a second opening pick and slide it to the top left corner.
    • Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
    • Remove the rear cover.
  8. Remove the Philipps #000 screw. Use tweezers to remove the metal plate. Use the flat end of a spudger, to disconnect the battery flex cable.
    • Remove the Philipps #000 screw.
    • Use tweezers to remove the metal plate.
    • Use the flat end of a spudger, to disconnect the battery flex cable.
  9. Disconnect the main flex cable with a spudger. Use tweezers to unplug the antenna cable. Remove the Phillips #000 screw.
    • Disconnect the main flex cable with a spudger.
    • Use tweezers to unplug the antenna cable.
    • Remove the Phillips #000 screw.
  10. Pry out the charging board with a spudger. Remove the charging board.
    • Pry out the charging board with a spudger.
    • Remove the charging board.
  11. Use tweezers to remove the vibration motor. There is some adhesive underneath so it might be a little bit sticky.
    • Use tweezers to remove the vibration motor. There is some adhesive underneath so it might be a little bit sticky.
    • When reassembling apply new adhesive where it's necessary.
결론
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it's necessary.
Theo Mat
회원 가입일: 2017년 11월 12일
10,629 평판
안내서 14개 작성하였습니다
My vibraiton motor is broken. I can’t find pefertly same motor in the internet . Can I use this vibriaton motor for replace
Derrick Ian - 답글
Hi Derrick,
it isn’t very advisable to buy a spare part, that doesn’t say it’s exactly for the Nexus 6P. It can happen that it doesn’t fit in the bracket for the vibrator in your phone or that it doesn’t work with it. Worst case scenario is, that it’ll cause higher damage to you phone than repair.
Dominik Schnabelrauch -
I design vibration machines. My vibrator motor is not easy to use. Do you have anything to recommend? Large vibrating motors are not used on mobile phones.
mclana - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 334
