주요 콘텐츠로 건너뛰기
Nexus 7(1st Generation) Battery Replacement
필요한 것
  1. Nexus 7(1st Generation) Battery Replacement, Taking the rear case off.: 1 단계, 이미지 1개 중 1개
    • Use the opening tools to open the rear case.
    • Be careful when opening rear case because the rear case clips can break.
  2. Nexus 7(1st Generation) Battery Replacement, Taking battery out: 2 단계, 이미지 1개 중 1개
    • Frist take the spudgler tool to move the wires from the mother board.
    • Second use the tool to pry the battery out of the top then do this at the bottom. Be careful when you do this because there is adhesive under the battery.
    • Im sorry I don't have picture of taking the battery out but the first picture in the circled part that is the motherboard.
    • When you put the new battery in you first put the battery in then you move the wires to the motherboard then but the case back on.
    • Turn the tablet on and there you go. Thank you for using my guide and if it was helpful please leave a comment or if something is not correct on my guide leave a comment and I will fix the correction in my guide.
결론
To reassemble your device follow step 3.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Skyler Wright
회원 가입일: 07/07/17
132 평판
안내서 1개를 작성함
2가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 28
전체 시간: 1,283
