주요 콘텐츠로 건너뛰기
Nexus 7 2nd Generation Back Cover Replacement
필요한 것
  1. Nexus 7 2nd Generation Back Cover Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Nexus 7 2nd Generation Back Cover Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Power down your device.
    • Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time. For some a finger nail may be best. The case comes up quite high to the glass.
    • Do not pry near the USB port at the base of the device as you may crack the rear panel.
  2. Nexus 7 2nd Generation Back Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Work fingers around the seam between device and back cover. Use your plastic opening tool and fingers to separate each side until device and back cover are completely apart.
    • Be careful around the corners. The body of the device can be fragile.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Heather
회원 가입일: 01/22/15
1,428 평판
안내서 2개를 작성함
Cal Poly, Team 20-16, Maness Winter 2015 Cal Poly, Team 20-16, Maness Winter 2015 회원
CPSU-MANESS-W15S20G16
4 회원들
안내서 26개를 작성함
4가이드 댓글
Step left out. ifixit.com video on Youtube show use of craft knife as first step to get into very tight case fitting, then the use of plastic pry tool to go around releasing the backcover.
nodakman84 - 답글
I didnt read the comment about it being tight and using a knife, until I had damaged the prying tools :-(
Bill Walker - 답글
How do u take off the cover do u have to have that tool
Sharon Catalli - 답글
I had very little problem prying of the back of my nexus 7 2012. Once you get the first corner done, the rest comes pretty easy.
I ended up using an old hotel keycard as a spudger and it worked fine.
I needed access to the cables that connect the touchscreen to the motherboard so that my touch screen would respond.
Worked like a charm!
Mister Muscles - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 55
전체 시간: 13,409
